How to code a clock
  • September 7, 2010
  • 8 replies
  • 3699 views
minutes go from 1 to 60 min and then reset incrementing Hour which goes from 1 to 24 and after that the day count is incremented and hour is reset.
How to do this in mathcad?
Best answer by RichardJ
Do you mean something like this?
Do you want this to actually show real time? Mathcad is not suited to such a task. Programming the counters would be easy enough, but they will not run in real time (more like several weeks per microsecond of real time!)
no not real time. i just need it to track the sun under arbitrary days and hours. not anything real time.
i need accuracy of 1min only.
You can use the modulo function for determining when something is repeat its cycle. However, you've not said what format your time data is in, so it's not possible to give you a better answer.
TTFN
