How to convert a nested vector into numbers
  • April 23, 2012
  • 6 replies
  • 3099 views
I have a probably very simple question. As a result I have a vector with nested values which I want to plt against a vector with numbers which is obviously not possible. How can I convert the nested vector into numbers?
Best answer by MikeArmstrong
There is a function called vec in the collapsed area of the attached worksheet which will do the trick.
Mike
Mike
FDS13-AquamarineAuthor
Mike, thanks a lot!
Filip
Your welcome.
Mike
Out of curiosity, how have you arrived with an answer as a nested array?
Mike
Well I use a very nice addition to Mathcad called Kornucopia (www.bodietech.com) which has some very powerful unpack functions for data files as well as some great functions for data analysis. It was by using one of these functions that I obtained the nested array.
thanks again for your prompt reply,
Filip
Cheers
The reason I asked was to try and iron out the issue of having nested arrays in the fiorst place, but I suppose using the pre-defined function isn't that taxing
Mike
