How to create a 3d surface/contour plot in prime 2.0
  • April 25, 2013
  • 11 replies
  • 7029 views
Hello All,
I have 3 vector for X, Y, Z but I am unable to create a 3d surface plot or contour plot of this in mathcad prime 2.0
I have read somewhere that is is not possible anymore but maybe there is a way to do it.
many thanks for the help.
Best answer by AlanStevens
One way attached.
Alan
One way attached.
Alan
many thanks for your reply, it works great.
I have altered the sheet a little te include my real data and use a contour plot i.s.o 3d surface.
Somehow the colormap is wrong, do you know how to fix that too?
You data ranges from -300 to -40, so you should change the colormap accordingly
See attached
thanks for the help, but in you file the colormap is also wrong.
I have values in the z matrix that are higher than let say -50 and they should be orange according to the colormap. But they are not.
