How to get a function run only when the worksheet opened in Mathcad
  • July 23, 2011
  • 10 replies
  • 4805 views
Hi Friends,
How to get a function run only when the worksheet opened in Mathcad?
This function can be easily solved by VBA Auto_Open macro in Excel,bu I don't know how to get it solved in Mathcad. Is there anyone can help me?
Thanks a lot.
Jeffery
Best answer by RichardJ
Richard has passed a components worksheet many times with a fantastic collection of scripted components, might be worth looking in there.
Good idea, but you wouldn't have found something to do this.
You would now though, because I modified the button that can be used to control execution of code
It's also in the attached file
I'm not quite sure what your after, can you post a worksheet?
http://communities.ptc.com/docs/DOC-1071#comment-3162
Mike
RichardJ19-TanzaniteAnswer
JefferyGu1-VisitorAuthor
Richard,thank you very much.
