20-Turquoise
Nov 7, 2020 5:10 PM UTC
How to plot a cup ?
Hello Everyone.
How to plot a cup ?
Thanks in advance for your time and help.
Werner_EAnswer
Nov 8, 2020 12:46 PM UTC
Now you can fill in liquid or trap a fly underneath 😉
Nov 7, 2020 10:21 PM UTC
One of many possible ways
lvl10720-TurquoiseAuthor
20-Turquoise
Nov 7, 2020 11:09 PM UTC
I greatly appreciate your time and help, Werner. Still have a very small query : How to add the base of the cup ?
Best Regards.
Nov 8, 2020 1:22 AM UTC
Just don't fill liquid in the cup 🙂
Werner_E25-Diamond IAnswer
20-Turquoise
Nov 8, 2020 4:27 PM UTC
"Now you can fill in liquid or trap a fly underneath"
Werner, I'm imagining I could fill in hot coffee now 🙂 and want keep it warm. And how to add the lid of the cup ?
    Best Regards.
       Loi.
Nov 8, 2020 10:26 PM UTC
You won't be able to access your coffee if you add the lid. But you can use the very same principle to add the tp surface as I did with the bottom (which gets the top if the height is negative, as you could see).
Simply map for example the interval from 1 to 2 for t to the range from r2 to 0 using another if statement in the definition of f(t). I'll leave it as an exercise for you to do 😉
But you sure could simply add a (slightly larger) lid as a separate cone of only marginal (negative) height:
