How to plot a log normal distribution function
  • April 6, 2010
  • 3397 views
Dear all, I desire to plot a probability density function of log normal distribution: f(x)=(1/sqrt(2*pi)*beta*x)exp(-ln(x/M)^2/2*beta^2) on Mathcad but Mathcad announced a yellow message "this variable or function is not defined above". I do not know at which point I am wrong, please help me to figure out. Thanks so much
23-Emerald V
April 6, 2010
Hi Stuart, Thanks for your reply, I figured out. It was a typo error I did. A point automatically appeared when I typed the formule. However, I have another question relating to inverse trigonometric function asin, it seems to return a weird result. For example, I want to calculate sinus of 1.7 radian, I typed on the worksheet sin(1.7) and Mathcad return the value 0.992. To verify the radian of an angle whose sinus is 0.992, I typed asin(0.992) while expecting Mathcad will return 1.7 but no, it returns 1.444 instead. Could you tell me what's wrong with my handling? How I can solve it Thanks very much
asin returns the principle value. It has no way to know which of the infinite number of possible angles you had in mind. 1.7 radians is 97.4 deg. 1.44 radians is 82.6 deg. The sin of both angles is 0.992. Richard
