how to slove the equation set
  • March 29, 2013
  • 16 replies
  • 5185 views
Mathcad was not able to find a symbolic solution (see attached).
Maybe more luck if you try clever substitutions / rewriting the equations, using keyword assume (e.g. assume, ALL>0). Symbolic evaluations can get tricky very quick.
For a numeric solution you would have to provide values for the involved five constants and guess values for the two solved for variables. Find in the attached sheet a solve block which was parameterized and turned into aa easy to handle function.
above all ,we can slove in paper ,but how can we slove in mathcad?
lee0714 李 wrote:
... but how can we slove in mathcad?
Like so?
Alan
Sorry.
I want at first know what physical phenomenon described by a system of equations, and then try to solve this system.
This system of equations is the mechanical principle of four bar linkage with complex number vector equations are listed,so it must be reasonable。
Welcome to the Group
http://communities.ptc.com/groups/kinematic-models-in-mathcad
...with complex number vector equations are listed,so it must be reasonable
Show the picture please
