How to use document properties inside the document
  • April 25, 2011
  • 17 replies
  • 9219 views
I want to use the document properties (author and title) and the file name of the Document and some custom defined properties to show them at the header of the document
(I want to use an embedded excelsheet to show the properties formated) and at the head line of each page.
At this time, I put a VBA script-object in the document, which reads the data using
Set metadata = worksheet.metadata
Set items = metadata.customitems
For each item in items
If (item.name = "m_discription") Then
Outputs(1).Value = item.value
End If
Next
(I'm not familiar with VBA, I found this code lines in a forum)
It works.
My questions:
-Is there another solution for referencing the meta-data inside the doc and inside the header and footer?
(As in Word, for example?)
-How can I get ,title' and ,author' from the builtin document properties and the filename?
H.Steffen
Best answer by RichardJ
As a minor technical point, it's not VBA, it's VBscript.
No. The only way to do this is via a VBscript.
Here's a function based on a scripted component that will get any metadata item. To get the filename requires another function based on a scripted component.
RichardJ19-TanzaniteAnswer
Nice worksheet.
Are you planning on putting your scripted components in the FAQ document?
Mike
Yes, I agree that shod be one of the linked documents. A ot of the components that people ask for are already in that document.
23-Emerald I
April 25, 2011
End If
Next
It works.
My questions:
H.Steffen
You can't insert a Header (View/Header/footer) and insert file information in them? Version 11 allows this.
I had forgotten you can get the filename and path directly in the header. But in versions 12 and later, no, they did not add the capability of directly accessing the metadata.
23-Emerald I
April 25, 2011
Created in version 14, printed to pdf file for discussion.
Thank you very much.
I will implement that code next time i my form!
If you are looking for scripted components similar to the examples posted here try searching for Extra Components, created by Richard, also Phillip Oakley created a good sheet with many useful functions.
Mike
