How to use radians or degree in the x-axis
  • September 5, 2010
  • 2 replies
  • 5036 views
I want to the x-axis to show radians like 0,Pi/4, Pi/2, 3Pi/4 pi etc or degrees like 0,45,90,135,180 degrees.
Right now it shows the decimal equivalent of radians
Best answer by MikeArmstrong
Something like the attached?
Mike
Mike
Correct. So i divide by deg and not use deg as the units of the axis.
Thank you it worked.
Mathcad's default display is normalized to the unit system specified in Worksheet Options|Unit System, so something with acceleration units will be normalized to m/s^2 in SI, and ft/s^2 in US.
TTFN
Mathcad does not directly display what you want for radians. You can use Mike's approach to normalize to pi, by simply dividing x by pi
TTFN
