I'm an idiot and having a simple problem w/ range variable
  • February 15, 2010
  • 1478 views
I upgraded from an earlier version... I define a range like this: x:1;20 which gives me a range from 1 to 20 incrementing by 1. When I enter x= I used to get a table showing all the values of x. Now I get a placeholder. How do I make mathcad give me a table with all the values of x??[/img]
23-Emerald V
February 16, 2010
Repaired v13, Now it works fine. I guess I should have done that to start with. I just figured that everything in v13 was working ok (symbolics, matrices, regular math etc) that it was some setting that had to be turned on. Anyway, now I have version 13 and 14 installed and running OK. Thanks for everybody's help!
