Import .CSV / .XLS which is specified by string
  • March 11, 2011
  • 15 replies
  • 9653 views
Hello Guys
is ist possible to specify the path of an file( which i want to import with the components shown in the attached jpg) by a string.
It would be nice to have the path somewhere in the mathcad-file saved, and the components use that string..
So that I dont have to use the ***** menu of the components!?
I hope you understand by poor english
Best answer by MikeArmstrong
I think I have found the problem. I don't think the function likes the .csv at the end of the page name. Try removing it and re-running the component.
Remember once the component has turned red you will have to right click, edit script, and click apply (tick sign)
Mike
Have a look at the attached worksheet, which uses a scripted component where range and sheet number can be specified within Mathcad.
Mike
Looks fine, but i get an error-message.
Make sure the path is correct. Can you upload both worksheets.
Mike
