Input logarithms with a fractional base
Probably newbie question
Is it possible to input logarithms with a fractional base? When I try it creates a rational expression. Parentheses don't work either. Or, must I change the base?
Joe
Werner_EAnswer
Yes, as long as the base is positive and does not not equal one.
What do you mean by that and why do you think thats not as it should be?
You don't show what you do and don't say what you expect, so we can't tell. Obviously when you want the logarithm of a base unequal to 10 you have to state that.
You know that in Mathcad log(a) means the logarithm of a to base 10, while log(a,b) ist the logarithm to base b of a.
If you want to take the logarithm of base 2/3 from an argument like 27/8 (which is obviously -3), you would type log(27/8, 2/3)=
23-Emerald V
Hi Joseph,
One example of a logarithm with a fractional base is the natural logarithm ln(x), with base 2.71828182845....
A logarithm of a value x (> 0) to any base b (> 0) can be computed as ln(x)/ln(b).
Or do you mean something else...?
LucMeekes wrote:
Hi Joseph,
Any base but b=1!
Werner_E25-Diamond IAnswer
That last part is what I was missing, thanks. I was trying to input it as it is traditionally typeset.
