Integral not evaluated with float integrand
  • February 17, 2010
  • 2 replies
  • 4011 views
Found another bug presumeably with Mupad.
Even very simply integrals with at least one variable limit dont' get evaluated.
See attached picture.
Assuming the limit or the variable x as real does not help.
Using MC_14_M030.
RMix
The use of a number with a decimal point in an expression forces float (numeric) evaluation (part of the specifications for the symbolic processor). With variable limits, such a numeric evaluation cannot be done, and it leaves the original integral expression.
__________________
� � � � Tom Gutman
>done
Why?
Richard
>>Why?<<
Because the result depends on the (unknown) value of the limit.
__________________
� � � � Tom Gutman
That's bug alright. A rather lame one, because if you change the 2 in your first example to an undefined variable name such as xxx the integral evaluates just fine. So it can evaluate the integral with no problem, it just can't substitute a floating point number afterward.
Richard
