20-Turquoise
September 16, 2010
Interchanging Row.
  • September 16, 2010
  • 11 replies
  • 5211 views
I really need help with following attachment file.
Regard,
Loi Le.
Best answer by RichardJ
It usually best to start by defining some basic helper functions. Firstly because they are reusable for other tasks, and secondaly because the main program is then usually easier to write.
Regard,
Loi Le.
It's not clear from your worksheet exactly what your trying to do.
What does "Given Input Picture" mean?
Mike
Does this help?
Alan
Alan Stevens wrote:
Does this help?
Alan
Alan,
Have a look at the attached programmed method.
Mike
Alan,
Mike
Mike,
Strictly speaking you haven't interchanged the rows, just moved the positions of the numbers 1, 2, 3 and 4. This might be perfectly acceptable, of course, if all the other terms in the matrix are identical (as they are in the example provided). Certainly a programmed method would be more flexible than my "handraulic" method.
Alan
Regard,
Loi Le.
I have replied few days ago ... interchange row/col ... I think you were the visitor, but if you change thread for the same subject, that does not help !
jmG
lvl10720-TurquoiseAuthor
20-Turquoise
September 20, 2010
Thanks a lot.
Loi Le wrote:
Thanks a lot.
The kind of interchange looks a "rotation"
