Best answer by LouP
Here's a MCD v11 file that works on the example you gave. I don't know how robust the symbolic processor on v15 is, or whether these keywords will work. The same expansions did not work in v14.
What is strange is that when I tried to add the same keywords from my example to your file (opened in v11), they didn't work, and the expression turned red. When I copied your expression into my old example file (attached, also in v11), then the expression expanded as you are looking for.
The problem is not a new one. You may be able to find a reference that has an algebraic solution for the spurious component at a freq n1*f1+/-n2*f2 as a fct of n1 and n2.
Lou
Hello Bill,
I'm not sure what you mean by that. Presuming you'd like to "simplify" the right hand side of the equation I suggest to take only this side and use the symbolic key word "expand" followed by the variable for which you want to solve.
Cheers
Raiko
LouP12-AmethystAnswer
Lou
BillDumke1-VisitorAuthor
Lou,
Thank you very much! That works great!
I sure am glad I still have Mathcad 11.
Bill
Lou's file for working with mathcad 15.
Regards. Alvaro.
