Intervals
  • March 19, 2012
  • 19 replies
  • 7699 views
Hi guys,
today i'm trying to write the ranges within which my variables can move. I want that an angle assumes the value of 0°, and that then it can change between 45° and 100°, for exemple...I state that, being a minimun function, i've just added two test values of these angles...
thank u
Best answer by RichardJ
OK. I see. I don't think it's possible to set a constraint like that. I think you need to solve for the four possible cases:
theta12=0° and theta23=180°
theta12=0° and theta23 varies within a range
theta12 varies within a range and theta23=180°
theta12 and theta23 vary within a range
and then choose the solution from those four that minimizes lambda.
Can you upload your worksheet?
BeNNy1-VisitorAuthor
Could you please indicate within the sheet where you need help. Users only have limited time to help and scanning through dense sheets takes time.
Mike
