Is it possible to plot a tensor (4D surface) in Mathcad 13 or 14?
  • May 3, 2011
  • 2 replies
  • 4688 views
I would like to plot a 4-dimensional surface using Mathcad. I think this would be a tensor, i.e. visualized as a 3D surface with vectors of various heights projected on top. I found in Mathcad 14 an quicksheet (Using Regress: Multivariate Regression) of a 3D plot using the 'regress' and 'mesh' functions. I wonder if this is the limit, or if I can plot a tensor somehow using these, or other mathcad 14 functions? Thanks - JCG
John!
Do you have a function of 3 variables - f(x, y, z)?
John_G1-VisitorAuthor
I have not yet generated the function in 3 variables - I have test data reduced to 4 sets of (3 sets of (a function of 1 variable))). Further data reduction is required. With the quick sheet method using 'regress' referenced in my original question, I will likely be able to get a least squares reduction to 2 variables.
So, in parallel with my first question, I have a second one. That is: Is there a way to generate a least squares data fit in 3 variables using Mathcad, perhaps using the 'regress' function?
JCG
It is possible. You must convert your matrix into 4 vectors f, x, y and z and use the minimize or minerr function.
See same task for 2 variables:
http://twt.mpei.ac.ru/ochkov/car/c_e.html
23-Emerald V
May 3, 2011
John,
You could try, as a starting point, something like the attached. However, it is rather contingent upon your 'surface' being amenable to such a representation. Sadly, the 3D plot component doesn't seem to allow setting of colour by x,y,z position otherwise that might be another way of visualizing the data.
Stuart
The example mathcad tensor plots certainly have all the graphic elements I have been seeking.
I will need to study the program you've written to generate the arrows as this is an aspect of Mathcad programming that I've not yet worked. I plan to attempt this method and get back to you with any detailed questions.
JCG
