Is MathCAD Prime still that bad compared to legacy MathCAD?
DJNewman
DJNewmanAnswer
You should see the Prime 8 version here: https://www.mathcad.com/-/media/Files/PDFs/Mathcad/Mathcad-Prime-8-vs-Mathcad-15-comparison-chart-en.pdf
PTC Marketer for Creo and Mathcad. I run their YouTube channels, some Creo campaigns, and all Mathcad campaigns and communications.
No, it has improved but is still some way off.
You can find in attachment - "Mathcad 15 and Mathcad Prime 7 Comparison Chart".
DJNewman
DJNewman19-TanzaniteAnswer
 David,
Thank you.
We also need to update this page:
https://www.mathcad.com/en/resources/webcast/whats-new-mathcad-7
https://www.mathcad.com/en/resource-center
It depends on what you exactly mean by "that bad".
IMHO Prime is still a shame and real Mathcad is far superior in many respects.
But decide for yourself whether the current version Prime 8 meets your requirements and wishes. Download and install it, test drive the full version for a trial period of 30 days and then make up your own mind.
Although you have accepted a "solution", simply having a table to compare capabilities is only half the story. Because it is simply a comparison table, too many of the Prime capabilities don't provide details about any item's behavior that can be missing in Prime that exist in Mathcad 15...like the way in which you have controls over elements of a plot, or the amount of points you can plot, etc., can paint a very different image of the true comparison. There are clearly aspects that are improved, but some significant capabilities are "watered-down" or missing...a table won't shed light on where those are. I hope PTC will address these BEFORE they sunset access to Mathcad 15 in another 3 1/2 years. We would like to have at least a year (or more) to convert files over with 2D & 3D plots that don't have labels and titles stripped, and collapsible regions that can also be expanded and shrunk WHILE locked, etc. This forum has identified a fairly substantial list of functions, and behaviors, that have not been addressed.
