3-Newcomer
Aug 17, 2026 12:49 AM UTC
Is there a way to modify or get Mathcad to add geometric algebra (or Clifford algebra diff name) into Mathcad
Was wondering if there is a way to mod or get mathcad to add geometric algebra (or Clifford algebra diff name) into mathcad. THis would include multivectors, the wedge product and the geometric product?
Not sure if there is any modding of mathcad at all for reference
Emeritus
Sep 1, 2026 4:37 AM UTC
Hi ​@Slacken,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Community Moderation Team
18-Opal
Sep 4, 2026 12:47 AM UTC
No. Mathcad doesn't have native support for Geometric (Clifford) Algebra, and PTC doesn't make an official plugin or add-on for it. Mathcad’s engine is hardcoded around standard linear algebra (scalars, standard vectors, and matrices), so it has no idea what a multivector or geometric product is out of the box.
If you have to use Mathcad for this, you basically have three options depending on how much work you want to put in:
  1. Hack it in the worksheet: Represent your multivectors as standard 8-element column vectors (for 3D space) and manually write worksheet functions like GeoProd(A,B) to handle the basis blade multiplication rules. It works, but it's tedious to set up.
  2. Write a C++ DLL: Mathcad has a C/C++ Custom Function API (MCADINCL.H). You can code the Clifford algebra math in C++, compile it to a .dll, drop it in Mathcad's Custom Functions folder, and call it like a native function.
  3. Drive Mathcad externally: Use Mathcad’s COM Automation API alongside Python to pass data back and forth, letting Python libraries like clifford or kingdon handle the actual math behind the scenes.
Realistically? If you don't want to build the math engine yourself or write custom C++ wrappers, Mathcad is the wrong tool for this. You'd be much better off using Python (clifford / kingdon), Mathematica (clifford.m), or MATLAB (Clifford Multivector Toolbox), which all have mature, ready-to-use packages for Geometric Algebra.
