Iterate through calculation
  • January 7, 2010
  • 7 replies
  • 4895 views
Hi all,
I have created a mathcad sheet that calculates beam curvature and strains. The sheet calculates these values for a single member.
Now I would like to iterate through this calculation and generate a table for a number of members.
I have a listbox that is populated with the members that I need to consider and I can run the calculation for each member manually. I'm wondering if there is a way for this to be automated and I could have a single table with the results.
I have attached the worksheet here. The sheet also reads a spreadsheet that contains the list of members.
Ali
See attached.
Regards. Alvaro.
stillife1-VisitorAuthor
Hi Alvaro,
That was exactly what I wanted to do. Thank you so much for your help.
Bests,
Ali
Where's the beef?
Are there British warships lurking off the coast of Montevideo?
