iteration help
  • December 14, 2010
  • 10 replies
  • 5416 views
Does anyone know if there's any documentation on an abstraction for iterative algorithms to solve systems of equations?
D
Best answer by RichardJ
Look up "solve blocks" in the help.
RichardJ19-TanzaniteAnswer
Why don't you post an example of your problem?
Mike
Mike,
This is an example:
x=sqrt((y-z)*2/r)
z= f*(L/D)*(x/2g)
f= something crazy with x in it
etc…(there are more equations with x in it)
So:
I say I need r to find x, but I need x to find z. I also need x to find f which is a part of finding z. So I guess a value for x, and then I use that value to find r and f. Then I go back and use the value I found for r and f to find x. I keep doing this until the guess and the calculated are the same.
Hopefully this helps,
D
Richard is right. You could use a solve block and set up a series of simultaneous equations.
Mike
