Iteration using "Line" -option
  • October 11, 2011
  • 4 replies
  • 1888 views
I have two functions which are depenent on each others results. Calculation as attached.
Can this kind of iteration problem be solved using the "Line" -option of programming toolbar?
Thank you for your help.
Best answer by wayne
Actually, as presented, I don't see any need for iteration or the solve block, just algebra. The solve block just spit out the original values (with a little error).
Perhaps some calrification of the problem is needed?
23-Emerald I
October 11, 2011
Mathcad has a built-in construct for this; you could program it, but "Given/Find" is a better, easier way:
wayne12-AmethystAnswer
23-Emerald I
October 11, 2011
What was not clear in the sheet is that the 49 mm in the equation for R should really be the variable c; the equations are coupled. So you are correct, a little algebra would avoid the use of the solve block.
