Label error? "real number", label is set correctly?
I'm trying to plot the function listed below but it seems to have an issue with the label formating or something. I have a second copy of this file that was modified for other uses but does not have this issue. I checked the 'label' setting of each variable and made them the same as the other sheet but it obviously doesn't work.
When I try to use Vopen in another funtion I get errors as well like...
and...
Although in my other sheet, both yield a 1x8 array of answers...
What am I missing here?
23-Emerald I
I don't have Prime available right now, but . . .
Try putting the whole expression Vopen(a,l,OA) in place of just Vopen in the graph.
Hello!
Please attach your Mathcad Prime worksheet.
I am having the same issue. Was there ever a solution to this?
I have attached my sheet below, the issue is on the last page.
See the solution here -> https://community.ptc.com/t5/PTC-Mathcad/Please-Help-me-with-this-bug-Integral-functions-and-plotting/m-p/701654/highlight/true#M193251
