Line break of an calculatet equation ?
  • October 8, 2010
  • 3 replies
  • 6074 views
How can I make an line break of an calculatet equation, like in my attachment.
The key code "Control" and "Enter" are not working, when the equation is calculated.
Roger
Best answer by MikeArmstrong
You could post your suggestion in the thread below.
http://communities.ptc.com/message/153532#153532
Mike
There is no way to format the result of a symbolic evaluation so that it is on mulitple lines. The only thing you can do is copy and paste the expression, and then edit it.
Roschee1-VisitorAuthor
It would be nice, if Mathcad will make this function available in an new version.
My suggestion is, that the result of an equation will be "line break" ed on the
with of a page.
How can I give this feedback to Mathcad engnieers ?
Regards
Roger
Mike
