list box with multiple selection
  • October 14, 2011
  • 4 replies
  • 4405 views
Hi folks,
I lookig for a list box component or something similar for which I can make multiple selections in one shot (for instance, by presing the ctrl button as in excel).
Thanks a lot for your help
Best Regards,
-JM
May be so:
http://twt.mpei.ac.ru/ochkov/Mathcad_12/7_20_List.png
There is a multiselect list box here:
Extra Components.mcd
Search for "Dynamically filled list boxes"
jmit1-VisitorAuthor
Thx for your answer Richard.
Does it work out properly for you?
For me, component not really reliable.
Also, do you know a way to change the size of the box?
Auto-adjustment ?
thx anyway
-jm
In what way?
Auto-adjustment ?
I can add seom inputs so that you can easily change the height and width. Autosizing is not available though.
jmit1-VisitorAuthor
1) By reliable, I meant that if I press left click + crtl once on the first item, the third and finally the fifth, it will select everything or unselect my initial selection.
++> Same observation with other scenarii.
2) I tried to add arguments like MSlistbox.Height = 11 etc... at the beginning of the script but seems not working!!
Thx for your help on both items
JM
Hmmm. Works fine for me. If I select 1, 3, and 5 then that's what I see in the output vector. Which OS are you using?
jmit1-VisitorAuthor
Not something fancy ... just XP!
May I ask you to help me to resize the listbox, please?
Thx Richard for your valuable support
Best regards,
-JM
