Listbox
  • October 15, 2011
  • 6 replies
  • 3064 views
When the selections inside a listbox are text. Mathcad will assign the row number of the selected item in the list to the variable . is it possibel to have the variable = the text of the selected item in the list? Thanks !!!!!!!!
Best answer by RichardJ
See the attached example.
just to clarify my question above:
if The listbox Code:= ASD
LRFD
where ASD are the selection in the listbox, when i select LRFD, then Code=2
is it possible to have Code="LRFD" rather than the row number?
becuase all my condiional "if" statments are based on the condition of whether "Code= "ASD" or "LRFD"?
Thanks!
i am attaching a mathcadsheet to clarify my questions above. Does the script for the listbox need to be changed to be able to accomplish it?
RichardJ19-TanzaniteAnswer
