Looping with two criteria
  • January 19, 2012
  • 5 replies
  • 2703 views
This question is regarding iteration with two simultaneous criteria.
I've been able to solve this with relatively simple manner (in the beginning of file), but I believe that this problem could be solved also with "while" operator (tries at the end of file), which could be then modified to solve a more complex problems.
Thank you for your help.
Best answer by MikeArmstrong
Like the attached?
Mike
Pretty fast work Thank you.
No problem at all. You caught me on my dinner
