"match" function: what to do with the ( ) result?
  • April 26, 2012
  • 6 replies
  • 5293 views
The "match" function returns a result in ( ).
I would have liked to use the value returned by "match" as an index, but if I try to assign the "match" result to a variable, the variable is flagged as "undifined" when called further down the road.
"Help" is not much help on that.
Is there a way to make usage of the (value) returned by "match", or can this function be used for informational purpose only?
Thank you.
Best answer by MikeArmstrong
Yes, write match(z)[0
See if that works.
Mike
See if that works.
Mike
23-Emerald V
April 26, 2012
See if that works.
Mike
with the caveat that this will return the first match - it may be worth checking if there are other values in match.
Stuart
Good point, but Laurent did say value.
Mike
LIke below if you have a single match.
Mike
