mathcad 15 vs 14
  • January 10, 2011
  • 6 replies
  • 13059 views
Good evening everyone,
If I write my programme in mathcad 15 it is possible for my lecturer to open it with mathcad 14 right?
I'm guessing the answering is yes since you can save it as mathcad 13 and under, but mathcad 14 isn't on the list. I just wanted to make sure.
Thank you
Best answer by MikeArmstrong
Yes, you can open worksheets created in Mathcad 15 with Mathcad 14.
Mike
Mike
can you please give me a hint how this works? I fail to open v15 sheets in v14 - also if they are converted to v13 first.
Is there a special procedure to follow?
Mathias
Mathias,
There is no schema change between Mathcad 14 and Mathcad 15, because the new functions and features added for Mathcad 15 did not require changing the schema. That means that you should be able to open Mathcad 15 files directly in Mathcad 14. The only thing that will change to images are the new features in Mathcad 15.
I no longer have Mathcad 14 on my system, since the two versions cannot coexist. Perhaps you can post the worksheet that won't open in Mathcad 14, and someone can check it for you.
Mona
