Mathcad ABC: I Is for Include Worksheets
- May 24, 2011
- 2 replies
- 3706 views
Most engineers have the need to standardize definitions, programmed functions, and some calculation formulas across their Mathcad worksheets and even more so across departments and the entire company. The Include Worksheet or Referenced Worksheet feature allows you to include a worksheet of definitions inside other worksheets.
Including standard definitions, programmed functions, and calculation formulas at the start of every worksheet, saves you time and helps ensure that your calculations are consistent and based on the same assumptions.
Best Practices
- First develop standard worksheet definitions and formulas that can be verified and documented.
- Gather the definitions and other common elements like functions into one or several worksheets and post them on a network.
- Start all new worksheets by including these verified worksheets.
If a value needs to be updated, it's a far easier matter to update the definition worksheets, rather than having to track and update a formula in all existing worksheets.
Including Worksheets in Mathcad 15
In Mathcad 15 and earlier versions of Mathcad, including one worksheet inside another one is called referencing a worksheet.
Inserting a reference to worksheet A inside of worksheet B, makes worksheet B behave as if you had inserted the actual regions from worksheet A inside of B, at that location.
- Choose Reference from the Insert menu.
- Browse to select a worksheet to insert or type in the full path or Internet address to a worksheet.
- Choose "set relative path", if you want a relative path rather than an absolute path to the worksheet. If you move both worksheets, the relationship between them is retained.
The referenced definitions and functions take effect at the point of the insertion and below it.
Note, if you make any changes to the included worksheet, you must press F9 (Calculate) before the changes can take effect.
Example
- Worksheet A contains definitions for the variables below:
2. Create Worksheet B with your calculations.
3. Insert a reference to Worksheet A above the calculations in Worksheet B:
4. Define a formula using the definitions.
Axial compression stress
If you update the definitions in Worksheet A, the calculations in Worksheet B and all other worksheets based on Worksheet A, will update upon recalculation.
Including a Worksheet in Mathcad Prime 1.0
Including a worksheet into another worksheet works very similarly in Mathcad Prime 1.0. We've added caching of definitions.
You can cache the definitions in Mathcad Prime 1.0. In earlier versions of Mathcad, if you moved a worksheet with included worksheets, and forgot to also move the included worksheet, the definitions would no longer work. That makes it difficult to share files.
In Mathcad Prime 1.0, choose Cache Worksheet from the Input/Output tab and all definitions from included worksheets are cached. Caching is on by default. Only necessary calculatations are cached, keeping the parent worksheet from becoming too large. Caching included worksheets, makes it very easy to share or to move your worksheets, without worrying about forgetting any of the extra bits.
