You may use "match" and "on error" but it sure will not be good enough for educational purposes then.
Your routine returns a wrong result for strings just one character long - a tough problem for cryptographic character frequency methods .
You may also consider turning the routine into a function and making it ORIGIN-aware.
Maybe also adding a custom error message if the argument is the nullstring.
Werner Exinger wrote:
Sorry, my zero knowledge of Russian language prevents me from commenting on your article.
Here http://communities.ptc.com/message/228806 for example
One foreign language is one method of CRYPTOGRAPHY!
So we are happily awaiting your language translation routine in Mathcad 😉
