Mathcad Community Challenge September 2022 - Resistors in Parallel
  • September 8, 2022
  • 32 replies
  • 19528 views
This month’s challenge is related to electrical engineering. We have a simple circuit with an electrical potential of 220 Volts. Initially we have a single 10 Ohm resistor. Then we add a second resistor in parallel, with 10% higher resistance. Then we add a third resistor in parallel, with 10% higher resistance than the previous resistor. And so on.
  • Calculate the current in the circuit for the single resistor case.
  • Calculate the resistance of each additional resistor and current through each resistor for 2, 3, 4, 5, and 10 resistors in parallel.
  • Can you write a function or program that calculates the resistance of each resistor and current through each resistor for n resistors in parallel?
These calculations are fairly straightforward, so it will be interesting to see what tools – vectors, matrices, loops, plots, charts, etc. – that you use to solve the problem. As always, how you document your calculations is important as your worksheet will be visible to the community.
Here is an example of three resistors in parallel, as drawn in Creo Schematics:
Find the Mathcad Community Challenge Guidelines here!
Here's a solution in Prime 4 express.
23-Emerald I
September 8, 2022
Calculating resistance and current for each resistor is simple.
Calculating resistance and current for the network is more pertinent:
Prime Express 4 attached
RantEng
I like to use Mathcad symbolics for insights into how to derive solutions.  My final and generalized answer for the total resistance equation is:
The complete solution is attached.
Robert (Bob) Adams
ttokoro
In your Mathcad sheet, you write,
When then the resistance approaches zero.
However, Fred, ppal and others show the total parallel resistance is
t.t.
RantEng
Good catch.  I stand corrected.  I was not considering that the the resistors are increasing in value.  Before stating so, I should have taken the extra step to derive the limit as you did,
Bob
Robert (Bob) Adams
18-Opal
September 8, 2022
ttokoro
ttokoro
Prime 8 with plot.
t.t.
ttokoro
t.t.
Here's another incarnation, using recursion to generate the resistor values:
Prime 4 attached, works also in Prime Express.
18-Opal
September 11, 2022
Just another one.
Some nice analyses, indeed.
But... don't do this at home!
Even just the first 10 ohm resistor is dissipating 4840 Watts, and the others not much less!   Gonna get toasty in there!
23-Emerald I
September 17, 2022
Yeah, don't try this as home,  Or anywhere else but as an exercise.
(We could argue that you deserve the burnt fingers and having to sweep up the charred remains, but . . .)
 Here's your sign!
