Mathcad default Line Thickness
the problem is simple:
Is there a hidden option to set the default line thickness (weight) in an X-Y-plot to a user defined value ?
Thanks for your help
Holger Schwaab
Holger Schwaab
Assuming we are talking about Mathcad 15 you have to load your template file (usually normal.xmct in the template directory under the program dir) and go to "Format / Graph / X-Y Plot". If no graph is selected the changes you make here are valid for all graphs in that sheet that you generate thereafter and as it is the template file they effect in the future all graphs in all worksheets you create which are based upon that template.
Mathcad Prime 2.0 on the other side is a very, very unfinished product and as far I know there is no way to change any defaults pemanently.
WE
No account yet? Create an account
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
