A
Anonymous
November 17, 2010
MathCAD ODE Problem
- November 17, 2010
- 4 replies
- 5594 views
I'm working on what I though to be an easy problem to predict temperature of a tank as a function of time. The tank contains water and some solid pellets, each containing solvent. The tank is heated with a steady source of energy. The solvent is boiled off. The solvent fraction of the liquid, pellets, and evolving vapor are all known and are each a function of temperature.
Odesolve seems to work but when I attempt to get an answer from the generated function or generate a graph, an error "This value must be a scalar" is reported.
It really has me confused. Obviously I don't use Odesolve often enough. Any help would be appreciated.
Best regards,
