Mathcad Prime 2.0: Default location of Mathcad Prime workshets and associated excel files
  • April 18, 2012
  • 3 replies
  • 2281 views
I inserted an excel file using READEXCEL. Although it is working fine, I see that the same excel file(s) and my Mathcad Prime 2.0 working files are saved (mapped) in ''...\Libraries\Documents" folder. Can I set file save options to prevent this happening from. Pl. help.
Do you mean the default save path?
I have just saved a Mathcad Prime worksheet to my desktop, closed it and reopened Prime - the new default save path was were the previous worksheet had been saved.
Mike
RWickrama10-MarbleAuthor
Thank you for your reply.
I think, the reason is that I am running all my files from a removable hard disc. For example, I noticed that When I disconnected the external hard disc, it also deleted all the files created (mapped) in the library folder.
Yes I've had the problem before. I usually save the worksheet to the computer hardrive and work from there.
Mike
