Mathcad Prime Maximize function
- May 19, 2011
- 13 replies
- 12539 views
I want to use the maximize function on a programmed function list, but I am starting to think it might not be possible to do it..
i want to find the max value (either X so that i will enter it back in the formula, or the max value on the graph).
See the bottom of page two of the script for further explanations.
Thank you very much.
PS: i would also like to know why does the graph acts as steps instead of curves? isn't the M graph supposed to be parabolic?
