Mathcad Prime Problems
  • October 6, 2011
  • 3 replies
  • 2990 views
Why does mathcad prime not support word or excel objects? Everything I have done with Mathcad version 14 now will not work do to heavy use of objects in my mathcad files.
23-Emerald I
October 6, 2011
Prime is a work in progress. All of the features in 14, 15 will eventually (we're told) exist in Prime (2 or 3 or 4 or . . . .) That's why when you buy Prime you get a freebie--the latest version of the "real" Mathcad.
Could you give an example?
Mathcad Prime 1.0 is not yet fully feature compatible with Mathcad 15.0 (or Mathcad 14.0). Because of this, you can install and run Mathcad 15.0 using your Mathcad Prime 1.0 license file. This arrangement will enable you to use all of your existing worksheets in Mathcad 15.0, while beginning to create new worksheets with Mathcad Prime 1.0.
If you need instructions for installing Mathcad 15.0 you can start here:
Online Mathcad Support Center
Chris
