Matrix function of 2 variables
  • March 17, 2012
  • 6 replies
  • 2742 views
Hello everyone!
I have a function to two variables of which I must find the minimum. I tried to make the matrix of values ​​of two variables for which there is minimal, but logically, they are two values​​, although the procedure is correct, the matrix does not express the values ​​... is there a way to do it? or is there another way to build even then with excel column by column? I am attaching the file.
Thank u!
Best answer by ValeryOchkov
See the attach
BeNNy1-VisitorAuthor
Great! Thanks again!!
I understand that it works if i reduce intervals, but i don't understand why did you introduce time...can you explain it?
It's nothing to do with the reduced number of intervals* or the time function. Select the matrix of interest; go to Format/Result. Select the Display options tab; change the Matrix display style to Matrix; tick the Expand nested arrays box. This works in your original worksheet.
I guess Valery got fed up with waiting for your solution to finish calculating so he reduced the number of intervals.
Alan
* Well, it's very slightly to do with the reduced number of intervals! If you choose a small enough number of intervals, you don't need to change the Matrix display option to Matrix - you can leave it at the default Automatic. You still need to check the Expand nested arrays box though.
