Maximize Function: MC 15
  • April 23, 2013
  • 18 replies
  • 6132 views
All --
Any ideas on why the attached sheet bombs? The error is (of course) "This variable is undefined", but I have been using MC long enough now to know that when you get that error in a solve block the absolute last thing that is likely wrong is that you have an undefined variable. I note that if I remove two of the conditions in the solve block, it works. Maybe this means there is no convergence?
Thanks in advance.
Matt
Best answer by MoeSzyslak
OK, I'm an idiot. Worksheet (below) now works correctly (I think). Putting it in to production mode to look for remaining issues. Thanks, all.
1. The vector p is a constant.
2. Plot please H(p) function
Valery -- thanks for the reply.However, I'm not sure that I follow you. I provide guess values for p that are constant, but the vector values are, themselves, the parameters being optimized in the solve block. As for plotting the function H(p), that doesn't make sense. H takes the vector p as input and provides a scalar output. I'm not exactly sure what you would like for me to plot.
Matt
Moe, if You would like to find a maximum of a function with one argument You can plot this function and see this maximum.
I think so.
OK, attached is a modified sheet that calls the Maximize(f,v) function 'n' times. It executes without error, but the results are incorrect. What am I missing? Thanks.
MoeSzyslak12-AmethystAuthorAnswer
Good idea, but why log to the base N? The values of v are essentially the same if you use base 10, though you don't seem to get the same H(v) as in the single run worksheet (suggests perhaps that your hypersurface has a steep spike in it?).
Alan
