Minimum/maximum in matrices
  • February 23, 2011
  • 5 replies
  • 5512 views
I need to find for each column of a matrice the minimum value (> 0) in that column (pos_6 as defined by the attached ; the maximum is obtained by using "max" function..). Please help!
Kind regards, D.
Best answer by StuartBruff
Dumitru Moldovan wrote:
It's about finding the minimum positive number foe each column in the matrice...Thanks for the attached. I'll take a look into it.
OK, Dumitru. Try the attached worksheet with function minnzpos1.
Stuart
23-Emerald V
February 23, 2011
Kind regards, D.
Dumitru,
I'm not quite sure the attached will do what you want, but I've created a function, minnz, that hunts for the minimum nonzero number. Do you require it to specifically look for the minimum positive number of just the least number > 0?
Stuart
Dumitru1-VisitorAuthor
Or if your matrices aren't really big maybe you can use something like this:
Magnus
