modelling master equation- Need help
  • April 13, 2012
  • 10 replies
  • 3978 views
Hi ! Need some help on modelling stuff
Say I have two equations with simple polynomial form
Y1 = a1 X^2 + b1X +C1 at 50deg C
Y2 = a2 X^2 + b2X +C2 at 100deg C
I need to model a master equation that can predict any equation between 50C and 100C
Say what for example what will be the new equation at 55C based on above two equations. That means we need to predict any equation( at specified temperature) with these two equations as boundary conditions.
Any suggestions ?
Best answer by wayne
As Mike suggested, you can interpolate (only linear though, unless you have some other criteria)
Could you not use pspline and interpolate between?
Mike
wayne12-AmethystAnswer
Thanks Wayne, the approach what you have presented is quite helpful.
Cheers
23-Emerald I
April 13, 2012
You guys beat me to it. The only possibility is linear interpolation, but I would do the interpolation in K, not C. There's no way to know whether it's actually linear in eoither unit, but I would argue that if it's linear at all then it's more ilkely to be linear in K.
23-Emerald I
April 13, 2012
Whether it's K, C, F, or R; it's fifty units wide. the "linterp" function does slope and intercept. I expect (haven't checked) that the linear interpolation would deliver the same results.
I have some problem - two functions of density-concentration of HCl at 15C and 20C.
Use please my Mathcad Server:
http://twtmas.mpei.ac.ru/mas/worksheets/C_HCl_t.mcd
and download the Mathcad 15 function:
http://twt.mpei.ac.ru/TTHB/1/Water-chem/functions/C_HCL_t.xmcdz
