my experience with creating an e-book
  • October 8, 2012
  • 0 replies
  • 612 views
I just finished creating a Mathcad e-book of my files used for my reactor modeling book and I thought I would share some thoughts.
My original "book" consists of a main file, and files for each example and appendix. To create the e-book, I followed the help guide in the author's reference. The only problem I had was discovering that the files can't have spaces in the names. Everything now works.
After going through the process, I have concluded that this e-book form is not appropriate for a text such as this. I think the only real advantage it might have over my other method is that the search function will work through all of the files at once. It seems that the e-book is more appropriate for a reference of data or of special functions that are self-contained.
Another disadvantage is the delivery of an e-book to a customer is more involved. The e-book consists of a folder with the files plus a .hbk file that is in the Handbook folder that contains the e-book folder. This requires more explanation on how to "install" the e-book. It's not that difficult for most people, but it could require more support from the writer.
I was also disappointed to find out the e-book doesn't allow links within a file, only to another file. Earlier versions of Mathcad have that capability. I knew it was gone in Mathcad, but I thought the e-book format might have it. Without that capability, the writer has to really break up the work into small files if he wants extensive linking.
For writers of textbooks, I don't recommend the e-book approach. For PTC development, e-books capability for Prime needs to be added for the reference type of works. For textbooks, what I think is more needed is just internal links within a file.
