Need help with ODEsolve
  • November 8, 2012
  • 2 replies
  • 2005 views
I'm having trouble using ODEsolve in MC14. I've gone through the examples, and they work fine. But the first problem I tried for real, doesn't work.
The solve block has only two lines, and only the first derivative of one variable. But I'm getting the dread "This variable is undefined" error.
I'm attaching the file. Any help would be appreciated.
By the way, I've selected the adaptive solver.
Jack Crenshaw
Best answer by Werner_E
If you really want v'(M) to be dependent on f(v) you have to write it as f(v(M)).
See attached.
Werner_E25-Diamond IAnswer
See attached.
JCrenshaw1-VisitorAuthor
Ah! Got it!!!! Thanks!!!!!!
