Normalizing x,y axis of a Contour Plot
  • May 24, 2013
  • 2 replies
  • 9979 views
Hello Experts,
I have a request that hopefully is not difficult. I have a matrix One
When I plot One the x and y axis is defined by the indices of the Matrix One
I need the X and Y axis to be normalized from 0 to 1 and from -1 to 1
Can you help?
Russ
thiirane1-VisitorAuthor
One additional comment.... I need the Matrix "One(x,y)" to be Normalized such that "One(m,n) such that m and n range from 0 to 1 and -1 to 1.
if you want it to normalize, how do you want the point between [0,1] and [-1,1] looks like? is it a contiuous contour or you just want a discret point (1) in every corner and zero everywhere? Do you want it to change linearly? exponentially? or some other way? You need to be more specific.
Hi Henry,
Thanks for helping...
Rather than having a Matrix whose x and y coordinates are defined by its indices, I need the Matrix to have x and y coordinates defined by the mapping from 0 to 1 and -1 to 1.
This is an exercise in the creation of a fractal. I need to have to spatial distribution to be mapped to -1 to 1 See the bottom of the attached.
Would the two approches in the attached file help?
The first is to use with a 3D contour plot. As a mtrix can't have non integer indices I created a function f(Q,x,y) which uses the table as a lookup.
The second is for use in a normal 2D plot. A matrix is generated where the first colum represent the normalized x-, and the second the normalized y-values of all those elements in the original matrix with a value of 1.
Another approach would be to create a matrix which represents a bitmap, as was shown in this forum some times with different fractals. This approach would be extremely useful for colorful fractals like a mandelbrot, as you would have more control over color mapping, etc.
