not storing Mathcad 15 worksheets!!!
I just avoided heavy losses by storing in Mathcad 12 format. Be aware that if you have to many points which you want to calculate and display mathcad runs out of memory when attempting to save the file. Also GSI+ errors may appear. So either you save only the file with limited number of points calculated before attempting to calculate more points or store the wrecked worksheet in Mathcad 12 format ignoring the warning.
It is really sad that you cannot caclulate a full year in a simulation with a step size of a second.
However it would be nice if PTC helps, so we don't risk to loose our worl and fixes this heavy bug!!!
best
Gerfried
