numerical inverse laplace fails
- February 17, 2010
- 1 reply
- 2863 views
Want to perform a numerical inverse laplace
transform on a polynomial.
Version 12 returns "no symbolic result found".
Colleague ran the file through Version 14 -
returns "Expecting an arithmetical expression"
Colleague also ran the file through Version 11 -
things calculate beautifully.
Anyone have suggestions? Ideas to get a numerical
solution in V12?
Hint: if you manually re-assign the poly values
rather than reading them from a file (as shown on
the 2nd page), the thing will calculate in V12.
Manually re-assigning things at every calculation
isn't an acceptable answer...
solution in V12?
