Object required:'Combobox1'
  • September 13, 2011
  • 9 replies
  • 4522 views
Hi Mike,
I use a ComboBox control to find all regions with tags and then scroll window to the region that you select from the control. It works well on a windows server. However, when it works on a citrix server it popups a error message :
Do you have any idea about the cause?
Best regards.
Jeffery
Best answer by MikeArmstrong
No problem Jeffery,
Let me know if you get it to work.
Mike
Jeffery,
Unfortunately I do not have an idea why it doesn't work on a Citrix server as I have use Windows.
Hopefully someone else on here will be able to help.
Mike
JefferyGu1-VisitorAuthor
Hi Mike,
Thank you all the same.
Best regards.
Jeffery
Been having a think and you could try the attached table of contents. Uses a listbox instead.
Mike
