ODE solve block functions in MathCad prime
- December 30, 2011
- 18 replies
- 12833 views
Can someone explain to me why this ODE solve block procedure (see worksheet attached) is not working with MathCad Prime 1? I did a similar exercise in MathCad 15 (see image)
using an equivalent formulation and all was OK. What I am trying to do is a sensitivity analysis with the parameter k which in this case is the thermal conductivity of the insulation material. For some reason the variable k does not seem to recognised by the solve block and thus the matrix of functions is not being returned to the variable.
