Optimization problem using minimize
- April 19, 2012
- 9 replies
- 3780 views
Hello all,
I'm trying to minimize the error in a function and have started with what I know to be fairly optimal guess values (achieved by using known good values and help from the Excel solver although it seems fairly limited in what it can do). It doesn't seem to work very well though. If I change one of my initial guess values it doesn't optimize back to the original optimal value.
Is it because I've set the problem up incorrectly or because the type of problem is not easily solved without further constraints etc. or something else I don't appreciate?
The mathcad doc attached is set up in the initial optimized state. If you alter the first element of vector "TCa" or "TCb" slightly, you will see the error curve in the first set of plots worsen. However, I would expect the optimization to have a good go at getting back to the optimal state, but it doesn't seem to.
I've tried to lay things out as neatly as possible but if there is any ambiguity please let me know,
Any advice gratefully received.
D
