Other problems with forum migration
Some of the threads from the PTC forums have not imported correctly. See the last two posts by richard.jackson and zhang6chao6 here:
https://communities.ptc.com/thread/6264?tstart=0
and in the original:
http://www.ptc.com/forums/viewtopic.php?t=7008
Only the quoted parts of the posts remain; the responses have been cut off. I also noticed this in at least one other thread imported from the PTC forums.
I have also noticed that all the embedded gif's from the Collaboratory are no longer embedded. They are attached to the post, but they no longer show in the body of the post. As an example I'll use the thread:
https://communities.ptc.com/thread/17512
Near the end there is a post from me which had 4 gif's embedded in the original. I don't have much hope that this will be be fixed, but it is certainly possible because if you know the URL you can embed the image:
Lastly, all the hyperlinks are wrong. See for example the last post in:
https://communities.ptc.com/message/89184#89184
which has a hyperlink that points back to the Collaboratory. I have even less hope that this will be fixed, but it doesn't hurt to ask.
